KD4UPL
Nov 24, 2013Explorer II
If you already have solar powering your coach batteries then there are ways to maintain the chassis batteries from that source. Some charge controllers have a second output for a trickle charge to a second battery; the Morningstar Duo is one. You could use a voltage controlled relay like the Blue Sea ACR to connect the banks when under charge conditions. Or the two devices pianotuna mentioned.
38,767 PostsLatest Activity: Sep 19, 2016
