J-Rooster
Jun 09, 2014Explorer
I suggest that you stick to your set budget, and begin to look for coaches in your price range! Make a list of coaches from your searches and find the best three coaches that have the floor plan that suits your needs the best. Then you can refine your search to the RV's length, engine, colors and service records. This should give you the knowledge you need to make an informed decision. I would like to add not to worry about a coach with high miles if you really like it, because your adapt to wear the inside of the coach out before the engine. Good Luck
38,778 PostsLatest Activity: Jun 10, 2026
