- TxsurferExplorerThanks all
- hostageExplorer
Bruce Brown wrote:
^^^ DEF is urea fluid.
DEF is Diesel Exhaust Fluid, which is urea.
yes I think most all know what I was alluding to; I guess I should have said DPF Diesel particulate filter system(contained in muffler) pre eura fluid systems but in the end one and the same arrived via different methods
I used DEF meaning Diesel exhaust filter - Bruce_BrownModerator^^^ DEF is urea fluid.
DEF is Diesel Exhaust Fluid, which is urea. - hostageExplorer
Tntman wrote:
In 2003 they added the EGR. 2006 came the collecter, 2010 came the DEF system.
my late 2007 ISL 425HP cummins has the DEF muffler/regeneration system
2011 (approx.) is when they went to the urea fluid cleaning system - Bruce_BrownModerator
hostage wrote:
Bruce Brown wrote:
hostage wrote:
BigSkyBob wrote:
When I ordered my rig I demanded a non DEF motor and they found one somewhere. So I have a 2008 rig with what I'm told is a 2006 Cummins motor. Kinda rare I believe. I generally get close to 10 MPG but never run my rig past the torque curve at 62 MPH/1450 RPM.
u must have a special order gear ratio also cause any 40 ft isc or isl diesel Motor home I have owned/driven are all about 1650 @62 MPH
and 10MPG is unheard of in either unit;;
JohnnyT has a higher rear end gear than ours and gets ~10 with his all day long.
well I don't know how as I have never read about owned or talked to anyone with a ISL that got better than 8.5 and that's flat land driving;; 10MPG must have been real easy freeway steady flat road driving I can tell you no one never averaged anything near that
We used to run around 7-7.25, after a few changes we do better now.
We also just returned from a 300 mile trip, some 2 lane, some interstate, some big long hills - and a LOT of generator usage (I'd say 20-25 hours anyway, maybe more) over the entire trip. On this one we averaged 7.6 INCLUDING the generator usage. Needless to say our MPG has indeed improved. - TntmanExplorerIn 2003 they added the EGR. 2006 came the collecter, 2010 came the DEF system.
- hostageExplorer
well I don't know how as I have never read about owned or talked to anyone with a ISL that got better than 8.5 and that's flat land driving;; 10MPG must have been real easy freeway steady flat road driving I can tell you no one never averaged anything near that - Bruce_BrownModerator
JohnnyT has a higher rear end gear than ours and gets ~10 with his all day long. - Bruce_BrownModerator
tinkerer wrote:
A lot of 2007 motorhomes have 2006 engines in them. That was before some serious anti-pollution devices. I own one of these coaches. I was told by a diesel mechanic the DEF engines are better engines than the bridge engines before DEF. ;)
We have a 2008 with a 2006 spec ISL. Not only does it need no DEF it can also burn the higher sulfur diesel. The best part was in our MH the ISL was a $6800 adder, however if we agreed to take a pre-emission engine they'd upgrade to the ISL at no additional charge. - Mr_Mark1ExplorerOur previous 2008 Monaco Dynasty 425 ISL Cummins with the first generation DPF design got a regular 7.0-7.5 mpg. We weighed slightly over 40,000 lbs. (sold with 70,000 miles).
Our current coach with the 500 hp Volvo with a DPF and DEF weighing 56,000 lbs., I'm calculating about 6.5-7.0 mpg. (currently, 39,000 miles).
Neither engine has given me trouble with the pollution equipment (so far on the current one).
Safe travels,
MM.
38,782 PostsLatest Activity: Sep 10, 2026
