dougrainer
Jul 30, 2013Nomad
Just did a 2008 Winne Journey that has a Kwikee/PG SYNC dual motor system. BOTH motors were bad. The front motor took about 1 hour.
The rear motor took about 2 hours ONLY because I had to cut an access hole thru the metal plate under the motor inside the compartment. Once I cut that access plate(removable), you can change the rear motor in 1 hour now. IF the same design for the same model year, then 4 hours tops to R&R the motors (Both). But, YES, both PG and Winne state that the hunting and jerking on the dual motor synch system is normal. Once the 2 new motors were installed, the jerking was not as prominent as before but you can barely see it now, The pass side(I did the drivers side) does hunt and jerk more than the new drivers side motors. Doug
