unixius
Jul 31, 2013Explorer
spotrot wrote:
Unixius - Thanks for telling me of your experience - just the kind of info I was hoping for.
The look-up page gave me part number 9010000160 and 9010000161, both listed as LH FRONT but I'll try to find a part number on the unit itself.
Did you have to open the slide, support the slide and then remove the entire assembly? I was hoping just to remove the motor and long shaft.
On mine, I opened the slide, but didn't support it. I was able to get the motor out without removing the slide rail, but, ended up removing the entire slide rail assembly. On mine, there are four hangar bolts to remove to drop the assembly, have at least one other person there to help!
There should be a sticker on the side of the outer rail with the exact part number. As far as I can tell, the 160/161 appears to be orientation of the motor on the end of the rail.
I looked at the parts diagram of your system, and almost all internal parts are the same as mine, the motor assembly is part number 1820111 (same as mine). Looks like about the only difference (quick look), is that yours is a 30 inch, mine is only 20 in...
