usersmanual
Nov 07, 2016Explorer
coolmom42 wrote:
Make absolutely sure that he and his electrician understand that it is 50 amp 120 V---NOT 50 amp 240 V! Otherwise it will cost you a LOT.
your incorrect
The 50 amp RV plug is the same as a 50 amp stove outlet. 50 amp RV plug is 240V in reality then it splits into two 120V runs as it enters the MH
you can take the 240V stove out of your kitchen and plug it into a 50 amp RV outlet and the stove will work just fine
-its a 30 amp welder plug in that u stay away from as its truely 240V only
that's why its 4 wire cable used 2 black- one white and a ground
38,780 PostsLatest Activity: Aug 05, 2026
