Tom_Anderson
Nov 17, 2021Explorer
bobndot wrote:MDKMDK wrote:
Transmission in P, and transfer case in N, and off you go
Is this a typo ? Transmission in P ?
No, not a typo. Transfer case in in neutral, so the transmission won't hold the vehicle stationary. If you put the transmission in neutral, it can rotate from transfer case drag, causing damage.
With a manual transmission, you put it in 5th gear. That's so it doesn't end up spinning the engine at 10,000RPM if the transfer case happens to drop in gear going down the freeway (like it would in first gear).
38,780 PostsLatest Activity: Aug 05, 2026
