supercub wrote:
I'm parked at an RV park in Las Vegas. Next to me is an older Marathon Motorhome. It's warm outside, so AC's are running, not heaters LOL. I've been stting outside I keep smelling diesel fumes........the generator is NOT running. However something in the nose of the motorhome is cycling on and off about every 5 minutes or so. Whatever it is, is very quite running and is smooth running.......nothing like a combustion engine. More like an AC unit, but quitter, and like I said, it's in the front and down low. Any idea what is running? I don't know if this is where the fumes are coming from either. If not, any idea where they might be from? Thanks
Brian
Marathon puts an air condiitoner behind the bumper (they will flip down)..... I think they call it a 'cruise air'.
Some Prevost coaches use a combination of cruise air and roof air. Bus air is usually in a side compartment with a large vent and mainly used when rolling down the road. You cannot get bus air with four slides, you will only have roof air.
MM.
