OhhWell wrote:
Safari360 wrote:
Thanks, Ohhwell. I appreciate the information. Why would a low mileage rig be a concern? I can think of a few reasons but would like to know for sure. I found a 98 Dolphin 35' with 31k mileage for 20k. It has a slide a looks nice in pictures. Thanks.
The low mileage is a warning (NOT a deal breaker) because that means that the drivetrain has not been run often which is not good for it. The thinking is also that if the coach just sat, it probably wasn't maintained as regularly as one that was driven often. Like I said though, it is NOT a deal breaker at all, just something to ask the owner about.
I'd add that at that mileage it may well have the original tires, which would have long since aged out of service. An immediate thousand dollar expense-or more, depending on the tire. Do be sure to check date codes on tires on every rig you look at.
Link to date code info. Note: If you see a tire with only three digits at the end of the DOT code, it was made BEFORE the year 2000.
Other rubber/seals etc. should be checked for soundness- I've been told that long periods of inactivity can result in parts such as belts/hoses/gaskets getting brittle.
Another routine thing to do for every rig you look at is to check for recalls, and if any exist to make sure the recall repairs have been made. Not sure which 1998 Dolphin this is- I don't see one identified as a "35 footer" at
this 1998 Dolphin specs page. But if it's the 5350, there is/was a
recall out for that model. Not a deal-breaking defect, in my opinion, but certainly something to check on when you look at the rig again.
