Safari360 wrote:
Hi Daveinet, I wanted to clarify that 20k is the initial investment that I have to spend on an RV today.  I will have another 10k or more to spend on it between now and when we leave in the fall.
Sorry, I made very incorrect assumption. If you do not require slideouts, take a hard look at an early 90s Foretravel. The Foretravel is built well enough, you may be able to squeeze some of your maintinance/repair budget into the initial purchase. Foretravel is not a production built coach, so the workmanship and material quality is a good jump up from your Monoco/HR, Newmars, and Allegros.
BTW: The Ebay Foretravel is too much money for an '85. If you are going that route, you want it to be new enough (ie 90s) to be a Unihome, Grand Villa. Those are a full monocoque construction. That is when Foretravel really came of age. Technically if you can find a '94, it would also have a 6 speed, which is of significant benefit as well, but may be pushing your target a little high. For a period of about 2 years I was watching Foretravels very closely. IF you are patient, you should be able to find an early 90s unit in the 25K range.
OK, here you go, try this:
http://houston.craigslist.org/rvs/4227213656.htmlBTW: I use this search engine for Craigslist:
http://www.dailylister.com/Search_Results.cfm?q=Foretravel&as_oq=rvs&cx=006225133476456637497%3Anhut7xqnd70&as_occt=Title&cof=FORID%3A11&ie=UTF-8&sort=date&newwindow=1
