ggrotzExplorerJul 11, 2015wheel cover nutshave a 2005 pace arrow 37a and want to check the air pressure in the rear tires.I am having trouble in getting yhe 2 nuts off of the wheel cover.I tried a inch and half socket but it was to small.I th...Show More
chuckftboyExplorerJul 11, 2015There should be enough room between tires to reach the valve stem. you will need a pressure gauge that holds the reading until it manually released
Related ContentWheel Cover Lug NutsNeed to find Chrome Hub cover Lug nut cover with nut...Wheel/Lug nut cover recommendationssimulator hub cap lug nut coversLocking wheel nuts - Ford
