rgatijnet1
Nov 03, 2014Explorer III
Using a regular socket, with an extension, will allow you to rest the extension on an adjustable jack stand for support. Once supported you can then get plenty of leverage to loosen or tighten the lugs to the 475 Ft even if you have to use your foot and a pipe extension on the breaker bar. Of course the lug nuts holding the wheel cover should never be very tight but sometimes they are put on using the same torque wrench at the tire shop.
38,780 PostsLatest Activity: Jul 20, 2026
