lj2654,
Well Sir, first off, there's a ton of different polishes, rouges, wheels and more out there. As one answer already stated, just make sure your wheels are not coated. It's real easy to tell. Anyway, once you've been able to determine they are able to be polished, then you determine just how much labor you want to put into the issue. It's a b it laborous in the onset but, once you've accomplished the shine, from that point on, it's about once every three months for a touch-up. And those take about 15-20 minutes per wheel.
If your wheels are not damaged by large scratches etc., you should not have too much problem getting them to the point you're satisfied with. In the pictures below, I've got an initial amount of about an hour and a half in each wheel. And, what makes a difference is if they're covered during storage periods. Our rig is under a drive-under cover and, the wheels are covered too.
I used a brown rouge and a 3" tightly sewn cotton wheel with a 2500 rpm drill to get the basics done. Then, I used some Zephyr 40 polish from Costco.com. Just about any higher quality pastes or liquid aluminum polish will do the trick for your. It's simply labor that does the job. I use those yellow micro fiber towels for polishing and small pieces of them for applying the paste or liquid. There are certain rags/towels out there that will actually scratch the wheels as you're using them to apply or polish the wheels. So, you have to be careful on which ones to do both jobs. Anyway, good luck and take your time.
Scott
