Bruce_Brown
Aug 31, 2017Moderator
eHoefler wrote:
If the speedy sleeve was installed dry or with a non hardening sealant like silicone, it will fail. The speedy sleeve needs to be installed over a hardening compund like JB-Weld. The other solution is to install a Stemco seal with a wear ring or one with a press on inner surface that does not spin on the spindle, it spins inside the seal assembly.
Depends on the SppediSleeve. Every one I've ever installed, which isn't many but more than a few, were drive on/press fit type and required no sealant.
I do like the Stemco type, for sure, and at this point after checking for axle run out I'd be doing that next.
38,782 PostsLatest Activity: Sep 02, 2026
