Kidoo
Aug 31, 2017Explorer
I will certainly check the breather again, all I saw the last time was a screwed in fitting and a hole with a bent rubber tube attached to the fitting. Is there something else than a hole as for breather?
I presume the shop checked it too, they paid for the seals and sleeves and the work the last time. Would it be because they are not competent? They change seals on big trucks, they would know how to do it by now.
What gets me is the fact that it allways leak on both side, I could see that one side is allways leaking if it would be the runout or wear on one shaft, but both wheel?
It was not leakin prior to the first replacement of the seals one year ago. The last seal that was installed is the one I got from Spicer. It is a W20HH100. On the seal it says it is a CR35000.
What would be the part number for a unitized seal?
38,782 PostsLatest Activity: Sep 02, 2026
