Bruce_Brown
Aug 31, 2017Moderator
Kidoo wrote:
I will certainly check the breather again, all I saw the last time was a screwed in fitting and a hole with a bent rubber tube attached to the fitting. Is there something else than a hole as for breather?
I presume the shop checked it too, they paid for the seals and sleeves and the work the last time. Would it be because they are not competent? They change seals on big trucks, they would know how to do it by now.
What gets me is the fact that it allways leak on both side, I could see that one side is allways leaking if it would be the runout or wear on one shaft, but both wheel?
It was not leakin prior to the first replacement of the seals one year ago. The last seal that was installed is the one I got from Spicer. It is a W20HH100. On the seal it says it is a CR35000.
What would be the part number for a unitized seal?
On the bold - that would make me look hard at the vent. Seeing as pressure is equal in all directions, a plugged vent, resulting in a pressure build up, should cause both seals to leak.
The axle runout idea was literally a last gasp at what could be causing this. As has been said before, it's just a seal. There are literally billions of them installed on everything from vacuum cleaners to large truck that work every day. Why yours is such an issue, especially after so many repair attempts, it a mystery.
With the leaking on both sides I'd think the vent would be about the only thing in the entire system that could cause them both to leak at the same time.
38,782 PostsLatest Activity: Sep 02, 2026
