Kidoo's avatar
Kidoo
Wheel seal leaking again and again and again
Hi, I am desperate. My rear axle wheel seal have been replaced for the fith time in on year on my Monaco Cayman 2003 Diesel. They still leak.
The last time they installed the seal I got from Spicer, the rear axle maker, and they also installed a speedy sleeve on the axle shaft.
After only 100 miles, it started to leak again on one side.
Any suggestions or axle specialist recommandation.
Thanks
  • It is doubtful that a Monaco shop can help you with a chassis issue. I think your best bet would be a large truck shop.
  • Mr.Mark wrote:
    Do you snowbird in the USA? If so, list a couple of States that you might be in and that might alert people to a good service center.
    Safe travels,
    MM.
    Yes I do. I was thinking to go to Monaco somewhere.
  • Do you snowbird in the USA? If so, list a couple of States that you might be in and that might alert people to a good service center.
    Safe travels,
    MM.
