IAMICHABOD
Apr 29, 2016Explorer III
leeper wrote:
When they come off your tire extenders that are attached the cover goes also. Instant flat tire can result.
DrewE wrote:
If I had infinite time, I'd probably get rid of the simulators and paint the wheels themselves nicely. It's hard enough to get to the valve stems with the twelve "hand" hole Ford wheels, and having simulators with slightly smaller holes doesn't make it one bit easier!
What is needed is a extended valve stem that will let you quickly check your tire pressure. They add no extra weight like the Extenders and are not attached to the simulators.
The best on the market,that are the original,are Tire Man
Chuck is the original designer of these an he has been around for years. If you have any questions just give him a call, he is always happy to help.
The kit looks like This it is for all 6 wheels,they also come with flow-thru valve caps so you don't even need to take then off to check the pressure.
Here is a list of all the products he sells.
