rgatijnet1
Dec 15, 2013Explorer III
wallynm wrote:
IMHO this is an old wives tale. Correct suspension and/or proper loading will provide an appropriate ride. This was dreamed up by some web site to sell reports and other information. They do not test drive anything before reporting.berreez wrote:
When you divide the wheelbase by the length of the motor home, you should have a wheelbase-to-length ratio of 53%. This ratio gives us a good idea of the handling characteristics you can expect from this vehicle.
From the above statement, is it better to have a number lower or higher than 53% if you what better handling?
I've had both shorter and a longer wheelbase coaches and proper loading is more important than wheelbase length. I've never had a tail wagging problem with either without resorting to a trac bar. I think trac bars are sold to people that think that they can buy every accessory and their RV will drive like their family car.
What is true is that those coaches with a shorter wheelbase will usually be more maneuverable if the rear overhang clears the obstacles.
38,780 PostsLatest Activity: Aug 05, 2026
