howdy35 wrote:
F20 shows to be the stereo and fans. On my chart, it is located next to F17. It is on the upper right hand row last fuse to the left in that cluster of fuses. It also shows to be a 10 amp fuse on the chart.
The engine starts on the two big batteries and sounds as if they are low. The generator starts on the 4 house batteries and the slides get power from them also.
I'm going to have the 2 12v batteries check today along with one of the 4 golf cart 6v batteries. The other day I added water to the 6v batteries and one of them took a lot of water. I have them set up with the connections where I don't have to pull caps to check for low water, when I started squeezing the filler bulb one of the batteries took a lot of water. Wouldn't it be nice if this is the problem. Let you all know later today.
That row of fuses are all 15amps on mine.
