Gjac wrote:
I don't either understand how a bad chassis battery can cause a fuse to blow when you turn the key on to start, unless when you changed the batteries a wire that was shorted to the frame was freed up.
I'm with you, but it's no problem now. My rain cloud is clearing up.
1. New chassis batteries fixed the blown fuse problem.
2. My generac generator (diesel) would run for about 10 mins then shut down. Found certified Generac shop, talked to him yesterday, pulled in today at 8:00am, out before 10:00am. They found a wire bundle that had dropped down towards the genny flywheel which damaged one wire, as he was getting stuff out of the way to fix the wire he found that coolant recovery tank hose to the radiator appeared too long and was kinked stopping free flow from the tank, then he found that somehow that hose had been pulled out of the tank so far that it didn't even reach the coolant. Wire fixed and hose repositioned correctly and now the genny runs great. Took her for a 30 mile freeway ride and both a/c's and the genny never quit.
3. Now, if I can just get one of the local RV repair facilities to return my calls for a new fridge cooling unit (waiting for almost 2 weeks) everything will be great.
Thanks to a response I contacted an Amish dealer in Indiana who quoted a great price on a cooling unit and it includes a 3 year warranty and if I pay 175, it can be extended another 3 years. If they weren't 1800 miles from me I would have them do it and tell my locals where can all go.
