Tinstar's avatar
Tinstar
When on inverter am I using the batteries?
When I'm parked, plugged into shore power and I'm plugged into the inverter outlet in the refrigerator compartment, is the electricity coming from the shoreline or from my batteries?
I guess I'm asking if I am draining my batteries with the refrigerator (or other appliance) by being plugged into an inverted outlet and replenishing them at the same time with the shore power or am I bypassing the batteries since I'm plugged into shore power?
Additionally, if it's coming from the batteries, should I switch to the shore power outlet to keep from running on them?
I hope my question makes sense.
  • Your inverter has an internal transfer switch. When it "sees" power from shore or generator, it "PASSES THROUGH" THAT source to everything downstream of it.
  • Depending how sophisticated your system is, some power management systems will temporarily draw power from the inverter/batteries if overloading the shore line. If the overload persists, the power management system starts shedding powered appliances.
  • It's inconsequential either way. The converter is supplying the 12 volt system when you are plugged in, and doing so at a far greater wattage than what your inverter would be pulling for a reefer.
    So even if your unit did not have an internal switching mechanism, the CONVERTER would actually be supplying the power, not draining the batteries, at worst, it would take a few minutes longer to recharge is all.
  • You are using shore power. The inverters have an internal transfer switch to automatically switch from inverter power to shore or generator power.
