FIRE_UP
Jan 17, 2014Explorer
rgatijnet1 wrote:
I look at the belts this way.....they are NOT expensive, and it can be a big problem if one breaks. For that reason, I change them out at 30,000 miles, which for me is about every two years. This way I can change the belt in the comfort of my own shop and not on the side of the road somewhere.
In most vehicles when the belt breaks you lose power steering, the water pump for cooling, alternator, etc. This means that you can only go a very limited distance after it breaks and your coach will be next to impossible to steer. Then think about where you travel and Murphy's law, which means problems will happen at the worst possible time. Do you want to be stuck at the side of the road, or at a location where you can't even get off of the road? Sure you have a spare, but will it break at a location that you can replace it yourself?
Belts are just one of of those things that are too cheap to ignore and too important for your safety to extend their replacement until they fail.
I also use Gates belts after one of my Dayco belts failed at 15,000 miles.
EXACTLY!
Scott
