dieseltruckdriver wrote:
I laugh to myself when friends use a four foot carpenters level because they thing they are more accurate. Once you are level, it doesn't matter how big the level is, as long it is correct.
It actually does matter. The longer the level, the better the accuracy. Here's why:
No surface, floor, wall, ceiling, whatever in an RV is perfect and true. This also applies to stick and brick construction.
If you use one of those little levels, such as a torpedo level, it can and will sit in an irregularity on the floor or wall, thus giving a false reading. If the floor has humps and bumps, which most do, a short level can have one end at the top of, and the other end at the bottom of a hump, throwing your reading way off. A four foot level on the other hand will bridge many humps and bumps and ride the top of them all, giving a much more accurate reading.
Now I will give you this about a 4 foot level, you sure as heck don't need one for leveling an RV. Its overkill. That fine of accuracy makes absolutely no difference. As long as its sorta close and the fridge works, all is well.
44 years in construction:
For building most stuff my 6 foot level is accurate enough. The 8 footer doesn't fit in my tool boxes or cab of the truck. My 4 footer is nearby for smaller jobs. My 2 footer and 18" are for short surfaces. Torpedo level is for 6 inch and under surfaces. If I'm building a 24 foot new floor sub base for a solarium and I want accuracy, I break out my laser level and shoot it every few feet. For that, I call an eighth of an inch in 24 feet close enough.
For my RV, my 12 inch level is fine.
But yeah, size does matter! :W :B
