rjstractor
Jun 19, 2022Nomad
brenden208 wrote:
I fixed the issue, simply enough, by cleaning up all of the terminals on the batteries and the relay above the alternator that Doug mentioned. Nothing was wrong but a bad connection. I did find the fusible links near the starter (passenger side, behind the front wheel), but they seemed functional. I was about to just run a new wire directly from the alternator to the battery to bypass all the rest of the relay nonsense, but no need! Thanks for your help everyone!
Glad you had an easy fix. First rule of 12V system troubleshooting, always check and clean connections before you buy any parts!
