tich's avatar
tich
Where is my water tank?
I have had my Fleetwood Excursion 39L for 10 years, and never bothered to find out where the fresh water tank is.
Now I have a leak - actually, a slow drip - which I assume is coming from the tank.It drips when the pump is on or off, and loses about a quart in 24 hours.
Does anyone know how I can get to the tank on this vehicle?
Thanks,
Tich
  • You need to find the exact place where the water is dripping from. Some fresh water tanks have a problem in that the overflow pipe will actually siphon water out of the tank and appear as a leak. My overflow pipe dripped water several feet away and on the opposite side of the water tank. Since I had a manual fill and vent above the tank on the wet compartment side, I just plugged the overflow several years ago to fix the problem.
  • It should have an overflow. Fill the tank until water runs from it; then it should be easy to find.
  • The tanks should be nearly exactly where the dump valves are. In my coach the freshwater tank sits at floor level with the black and grey tanks on top. My coach is not your coach but it might be a good place to start looking. There should be some removable wall panels allowing VERY limited access but you might be able to find the leaking connection (hopefully) once you get access.
  • If you think it's leaking from the tank, then the tank will be above where the leak is.
