et2
Aug 21, 2013Explorer
CloudDriver wrote:
The best answer for proper tire pressure is to have the RV weighed, then set tire pressures per the tire manufacturer's load/inflation tables.
The Michelin RV Tire Guide has lots of good info.
^^^^ this. I was having wandering and hard ride on our new MH. Weighed it and the tires were aired to almost max pressure. Aired them down to the weight based pressures. What a difference. Much easier to hold between the lines and way softer ride.
Our factory pressures are on a sticker behind the driver seat on the wall. And they are higher than what it should be based on the actual weight! So weight your MH, it only cost $10.
38,776 PostsLatest Activity: May 15, 2026
