MrsLJesuslover's avatar
Jun 02, 2016
Where is water control station
Bought a different RV. I now have a 1996 Damon Daybreaker. I don't have a manual but have been getting aquainted with it. However, I can't find the water control station! Not on the outside, not under the kitchen sink. Does anyone know where it might be?
  • MrsLJesuslover wrote:
    I only called it a water control station because I didn't know what else to call it lol. It is where you turn the levers to turn the water on to different spots like the bathroom or the kitchen
    You hook up a hose to city water connection..turn it on and open a faucet HOT side.....so water can go into water heater and fill it.
    When air is expelled and water flows hot water system is full of water.
    Then turn faucet to cold water side..expel air....won't take as long as hot
    DO same at all faucets/shower/toilet
    RV plumbing system is ready for use
    You can do same with on-board pump.........after you fill it via the gravity port connection on side of RV.
  • His 1996 Damon Daybreaker will not look like that for sure.
    mike brez wrote:
    Like this
  • I only called it a water control station because I didn't know what else to call it lol. It is where you turn the levers to turn the water on to different spots like the bathroom or the kitchen
  • It doesn't have a water control panel
    You connect water supply hose to city water connection on drivers side of RV by the power cord hatch
    You fill fresh water tank via gravity fill on opening at drivers rear corner of RV
    OLD School :B
    what is a water control station? :h
    x2???
  • Do you have any outside compartment doors? Try looking inside a lot of water and sewer connections are in the same compartment towards the rear on the drivers side. Hope this helps.
