DAS26miles's avatar
DAS26miles
Explorer II
May 25, 2015
Where to get a spare tire rim for new Ford F53 19.5"
We are looking at a new Winnebago class A Vista 26HE. It has no spare but has room in rear storage compartment. Looked online and couldn't find any plain rims. I want to see if I can get one in negotiations. Need the cost of rim, the tire cost was easy to find. I don't want to start a discussion on pros and cons of having a spare.
I will be calling roadside assistance to change a flat most likely. I estimate the tire will cost just under $500, but how much is a rim and who sells it.
  • conceptumator wrote:
    As was pointed out, most new RV's don't come with a spare and there's a reason. First, unless you have a good impact wrench with you, getting the wheel off is going to be nearly impossible. Getting the lug nuts torqued back on after changing is going to be even more challenging. All of this plus the weight of that monster wheel assembly your handling (or two wheels you get to handle if you blow the inside dual) is simply not something you want to do on the side of the interstate....
    ..This is mostly true, for larger Motorhomes that have 22" wheels/tires. However, the original poster here has a gas rig, with 19.5" tires. Not the same ballgame at all. 19.5" tires are lighter and easier to handle, not to mention less expensive (which are two of the reasons I'm glad my MH has such).
    I can tell you from personal exerience, that it most certainly IS possible for an owner to change a 19.5" tire by themself. I've done it. All you need to carry with you is a good bottle jack, torque wrench, socket, wrench, and breaker bar/pipe (3' long is plenty) to go on the wrench to break the lugnuts loose.
    Like already said, 19.5" wheels typically only require 150 ft-lbs of torque. You can apply that much torque pretty easily with the right torque wrench, that you can buy from Harbor Freight for around $30. If somebody has put lug nuts on tighter than that, then the breaker bar I mentioned and appropriate wrench, socket can be used to break them loose. Another option is to carry an air impact wrench and portable compressor to run it, which makes it even easier (but not necessary). The breaker bar also can be used to help you maneuver the tire/wheel into place, and pry it up onto the lug bolts.
    Anyway, I know the original poster said he didnt want to turn this into a debate of whether or not to carry a spare, and I don't want that to happen, either. I just wanted to point out that 19.5" tires are much easier to handle, change, and indeed CAN be handled by the owner with minimal tools, if they so choose.
  • If you want a steel wheel, I would find a shop that sells the aluminum wheels and see if they have one from someone who swapped their wheels out. They might even give it to you. A new tire for it is most likely going to run you around $500 mounted and balanced, valves, etc. As was pointed out, most new RV's don't come with a spare and there's a reason. First, unless you have a good impact wrench with you, getting the wheel off is going to be nearly impossible. Getting the lug nuts torqued back on after changing is going to be even more challenging. All of this plus the weight of that monster wheel assembly your handling (or two wheels you get to handle if you blow the inside dual) is simply not something you want to do on the side of the interstate. My suggestion? Get something like Good Sam Roadside, pull over, crank the generator and AC and wait for the repair guy to show up. They know what they're doing, have the proper tools and know how to work around the traffic. Terrible thing to get killed just to save the cost of Good Sam for a few years.
  • Got a brand new 19.5 Alcoa off of EBay, they have a lot of wheels, just gotta know exactly what you need.
  • Make sure you spec the right "bore" size for the wheel used by your vehicle on 19.5 inch tire. There are 2 different 19.5 rims with 2 different bore sizes. Mine took a 6.75 bore 10 lug pattern when I bought one from salvage.
    I think I used Visone for the used rim but there are others out there. It saved a boatload of money as opposed to buying new from Ford.
    Been a while but I think I got the rim for a bit less than $100 and a good new tire (not the Goodyears that came on it but a Sailun) with same load ratings and plys for about $250.I got the tire locally.
    Shipping costs are an issue on those heavy rims.
  • Most all new rvs don't come with spairs,but try a truck tire shop.
  • The one we are looking at to maybe buy has the 10 bolt steel rims. Tires are 245/70R/19.5.
    I figure asking the dealer to supply a spare is going to cost him about $700-800.
  • What size tires you have? Are your wheels 8 or 10 bolt? Steel or aluminum?
