DrewE
May 29, 2018Explorer III
Does the pull change when you apply the brakes? If so, you almost certainly have a brake that's dragging, probably due to a caliper that's corroded/stuck or a brake hose that's old and internally clogged somewhat. A steady side wind can also feel very much like a misalignment, though of course it would change direction when you turned around.
All that being said, there's certainly the possibility of needing alignment; I don't want to discount that at all, but merely observe that pulling to one side can sometimes have other causes as well, causes that have once or twice fooled me for a bit.
38,782 PostsLatest Activity: Sep 10, 2026
