pauldub
May 29, 2018Explorer
2WheelJB wrote:
Thanks to all for the replies to my post.
The motorhome went 40,000 miles on it's original set of tires. When they were replaced, more due to age than wear, the front treads showed no abnormal wear that could have been the result of a misaligned front end.
I put a couple thousand miles on the new tires without incident. However, our recent weekend trip of less than 200 miles had the vehicle pulling slightly, but consistently, to the left. The front tires are both inflated to manufacturer's specs - 65 pounds. And applying the front brakes has no effect -- it is not due to brake application.
Any further thoughts?
Jon
Did you replace them with cheap tires? You might try swapping the two front tires and see if the problem follows the tire.
38,782 PostsLatest Activity: Sep 10, 2026
