down_home
Sep 28, 2021Explorer II
Hunk of Cheese wrote:Rick Jay wrote:
Hunk of Cheese,
do you have the tires properly inflated for the load that they're carrying? Some places just air up the tires to the max inflation pressure on the tire, but that is often times over-inflated for the specific tire & RV/weight combination. I know on our rig that gave a very poor (hard) ride and made steering a bit squirrelly, especially on rough pavement.
Argh. Yes, I have the tires aired properly -- I keep them all at 90 PSI, which is slightly higher than the tire manufacturer's recommendation for my weight. Tire mfr. recommends 80 PSI which is also the tire's minimum allowed inflation and I wanted to stay above the minimum.
When I first got my coach and took it in for inspection, the shop filled my tires to 140 PSI. Ride was so hard. I came back later after learning some stuff and tried to tell the guy he had made a mistake. The whole shop was immediately very angry, (I guess they had had this argument before.) and somebody sarcastically yelled at me "if 140 PSI wasn't the tire manufacturer's recommended pressure then why would they stamp it on the side of the tire?!". They waved away and didn't want to look at my PDF brochure from the tire manufacturer. Wow, that was frustrating.
De-airing the tires did help a lot with the squirrely but it's still there.
Behind the seat on the wall or elsewhere there should be a label with recommended tire pressure for the coach.Our coaches do not weigh 100,000 lbs and the sidewall molded in maximum pressures are for a semi. We had the pressure for our tires raised in 2012 when the bays were filled with things for our kids, out near Tucson.
What a mistakeI59 was real bad then and it nearly beat us to death...and loosened everything in the coach including screws in the shower, the washer/dryer half out of the cabinet and so on.
38,783 PostsLatest Activity: Sep 23, 2026
