msmith1199
Feb 10, 2015Explorer II
GPS works most anyplace, but I'm pretty sure the XM antenna will need to be on the roof if you want a could continuous signal. You should be able to run the antenna wire up along the trim around the windshield. You're going to have to get up there and drill a hole so make sure you calk it good.
38,769 PostsLatest Activity: Apr 03, 2026
