Oldme
Nov 08, 2014Explorer
Ok then you have one of the KW series.
Make sure you have a good ground with the mounting bracket.
I removed some paint under mine and also try to get the
antenna at least a foot away from ant overhang.
If you find a CB shop they should be able help trouble shoot
the ground plane issue that is causing the high SWR.
Firestick's trouble shooting may also help.
http://www.firestik.com/Tech_Docs/swr-causes.htm
http://www.firestik.com/Tech_Docs.htm
Hope you have a good trip.
38,771 PostsLatest Activity: Apr 15, 2026
