CloudDriver
May 27, 2015Explorer
Replacing the shocks isn't the first thing to do to resolve an issue of getting blown around when driving.
Get the RV weighed - at least individual axle weights, but preferably 4 corner weights. Set the tire pressures based on the load/inflation table for your tires. If you get 4 corner weights, remember that all tires on an axle are inflated to the pressure required for the heavier side. Proper tire pressures make a big difference in ride and handling.
Over inflation of the front tires for the load reduces the tire contact area with the road, reducing the friction that keeps the vehicle from being blown around in crosswinds.
Have the front suspension and steering components checked for looseness and once worn parts are replaced, have the front end aligned.
Lots of posts here about adding steering stabilizers, track bars, sway bars to help with handling.
Do the cheap/easy things first before throwing $$ at items than may not resolve the handling problem.
BTW, I replaced the OEM shocks on our 24 ft MH on the Ford E-450 with the Bilstein Comfort shocks and my wife says it rides better. It still rides like a light truck though.
38,778 PostsLatest Activity: Jun 10, 2026
