Lobstah
Oct 04, 2013Explorer
prism wrote:RayChez wrote:
Lower the jacks first and level your coach that way you do not have any twist on the body of the coach if you are in an unlevel ground. Then extend your slides.
I believe Monaco has it just the opposite.
I suggest if the ground is that uneven then perhaps move to a flater spot or block wheels.However if its that uneven then probable level with jacks first and then slides out. However I have found as I have posted 3 times that in general while on REASONABLE level surface one should deploy the slides and then level with jacks.That is my opinion and found my slides go in/out more freely when done this way and as I previously posted so did my buddy with gulfstream whom had sticking slides.we are really talking two different situations here one being a normal flat RV space verses some obsure uneven parking spot
So your slides operate better when your coach is NOT level?
That's a puzzler for me, glad it works for you.
Jim
