CentralCoaster
Jun 21, 2017Explorer
Which Roadtrek front shocks? 9000 GVWR
1997 Dodge Roadtrek 190. I'm changing front shocks and I'm stumped.
All the manufacturers offer two shocks depending on the GVWR. I don't know if that means these B-series vans had different susupension geometry, or just different weight, but the two shocks are different lengths.
The Roadtrek GVWR is right in between these numbers. Bilstein says the higher GVWR shock is longer. I bought this shock and I'm worried about firms that since it's 1.75" longer than the original shock. I measured and it looks possible that the shock could bottom out at full compression and be damaged. See pic. By the oil marks it looks like not much of the stock shock travel is used though.
PIC:
[url]https://drive.google.com/open?id=0B0lNygTqqUADRGFTck90UDRtXzQ
Bilstein 24-014014. I've read others using this one but I want to make sure I do it right.
The shorter Bilstein is #24-184632
This is the catalog. http://www.bilsteinus.com/uploads/tx_templavoila/motorhome_0811_01.pdf
PIC:
