suprz
Jun 17, 2019Explorer
Which shocks IF...
You can't afford bilstein? I'm wondering if waiting to afford bilstein shocks versus getting shocks now is worth it, or even safe and which shock you would recommend
FunTwoDrv wrote:
Although we went with Bilstien shocks, my thinking is to go with the best shock you can afford. Our Chevy 4500 chassis had two completely worn out shocks at 17K miles... one front & one rear!Lumpty wrote:
I had Bilsteins on the front of my E450, and found the digressive valving too floaty as I'm lightly loaded with a no-slide 24' house. The front tires were cupping badly. Switched to a pair of Monroe Magnum RV shocks, which were all of something like $25/each using an Advance Auto coupon, and they resulted in a much more controlled ride, and also the tires are wearing evenly as the twin I-beam front end isn't going up and down all the time with it's inherent toe change.
Lumpy, could you elaborate on the "cupping" you experienced? Our current tires are starting to show cupping in the center of the tread. Scheduled Friday to replace all six with Michelin.
Gary
