You can't afford bilstein? I'm wondering if waiting to afford bilstein shocks versus getting shocks now is worth it, or even safe and which shock you would recommend
Ron, of course if your heavy duty front shocks also mean that they're stiffer shocks - then your front ride could be rougher than necessary for two reasons -> underloaded front coil springs plus shocks that don't compress/extend as easily.
Do you have rear air bags that you can adjust to permanently raise the rear and hence transfer more weight unto the front?
