wcjeep
Jul 14, 2014Explorer
jeeper5usa wrote:
PghBob. Thanks for the heads up on the show. I'll definitely be there!
With a 2000 pull, I can pull a little guy travel trailer with no issues. Might not be the most comfortable but at 55mph I don't foresee a problem.
That's why I'm asking, researching. If I tow the Wrangler, it will be on a trailer, I'm thinking behind a Class C. Possible? Recommended? It's either that or a travel trailer around 1500 lbs.
Your 2k Wrangler capacity includes people, fuel, additional weight of mods and armor. Hopefully your not still running the Dana 35. This sounds like the standard TJ wheel base, 94"? I wouldn't tow anything more than 5mph. Your bigger tires also decrease stopping distance.
I've seen some Class C's that are rated for towing your prospective weight. Say 3500lb Jeep and 1400lb trlr. Also, most toy haulers will not support a Jeep. Many have tie downs that do not connect to the frame.
A friend in my offroad club has a truck camper mounted on a gooseneck trailer. His MJ Comanche fits on the end all towed by his Dodge Diesel.
