wbwood
Oct 08, 2015Explorer
jeeper5usa wrote:
PghBob. Thanks for the heads up on the show. I'll definitely be there!
With a 2000 pull, I can pull a little guy travel trailer with no issues. Might not be the most comfortable but at 55mph I don't foresee a problem.
That's why I'm asking, researching. If I tow the Wrangler, it will be on a trailer, I'm thinking behind a Class C. Possible? Recommended? It's either that or a travel trailer around 1500 lbs.
I had a 2000 Jeep Wrangler with the 2000 lb rating. I towed a 1600-1700 lb pop up camper. It pulled it ok, but the problem is stopping. You will want to have some sort of braking for the trailer if you decide to pull something. The general rule of thumb was to stay around 20% under your tow rating. So a 2000 lb tow rating minus 20% would be about 1600 lbs. And that is not including any other people or cargo.
When you start talking about putting it on a trailer to tow it on, you are probably going to be over 5000 lbs (for both)...Unless you buy a new Class C that might have a higher tow limit of 5000 lbs, you will want to look at something larger. But be advised, many Class A's have a 5000 tow limit as well.
