Bandaid
Oct 30, 2021Explorer II
which way?
Hi folks, While I am not new to campers and towing them, this is the first class C I have owned. I am considering towing a small vehicle behind the rig. I would like to know the pro's and co...
btim wrote:
I am relatively new to this Toad life. I tried a dolly and found it too much of a pita, especially in freezing weather with snow on the ground. Bought a 2012 Honda Fit 5spd and set it up to flat tow. Much easier. Plus, I am cleaner and less pissed off when done. Wife and I get it done in less than 5 minutes. Towed it all over USA this past summer and now much prefer this method. Note to the wise: Do not try to do this w/o axillary braking. My Roadmaster braking system disconnected itself in the mountains one time. I could feel it immediately. That 2700# car was pushing my 14,000# E450 class C around a bit.Grit dog wrote:
Or if you’re good with a Jeep Wrangler and no toad brakes, couple hundred bucks gets you a tow bar and some magnetic tail lights. Easy peasy.
Does the Jeep not require a base plate? I often thought it should be simple to attach a tow bar to the recovery hooks on a Jeep or other 4wd vehicle.
