Bandaid's avatar
Bandaid
Explorer II
Oct 30, 2021
which way?
Hi folks,
While I am not new to campers and towing them, this is the first class C I have owned. I am considering towing a small vehicle behind the rig. I would like to know the pro's and cons to using a dolly, or tow bars. The only time I have towed a vehicle four wheels down was my car behind a rental truck. Found it to be a pain the the neck, as every time I pulled out of a parking lot, or side street, the cars front wheels would go the opposite direction of the way I was turning!
Bandaid
  • Your previous towing experience was not correctly done.
    4 down is preferred. You don't have to store, register or maintain brakes and tires on a tow dolly.
    Setting up a 4 down towing system will be about $3k. You’ll need to choose the appropriate vehicle to be towed. The vehicle manufacturer will offer that info.
    If you want to tow a FWD car that does not allow 4 down towing , then you need a tow dolly or flatbed trailer.
    With the correct 4 down car :
    That vehicle will need a base plate installed on the front of the car.
    The tow bar attaches to the base plate then to the 2x2 receiver on the rv.
    You need to add , Safety chains, electrical hookup and a break-a-way cord and a brake system for the car.
    I use a ‘Brake Buddy 2’ because i can use it on any car in the future. Its portable not a hard-wired braking system. I find it easy to use while towing my Chev Sonic automatic at 2700 lbs. The hatchback model offers addition 47 cu ft of interior storage, roof rack for canoe or additional storage box.
    For car lights :
    You can buy a harness specific for your car to operate running, brake and directionals.
    OR, you can drill a hole inside the taillight lens and install a 12v 1157 socket and bulb. Wire the sockets to a cord to the rv 7-way trailer plug.
    ** You can also run a charge line in that trailer cord to keep the car battery charged. Usually the trans is in neutral with the key on ‘ACC’ position. Doing ACC position opposed to ‘run’ position will normally NOT record your towing mileage on the cars odometer while leaving the steering wheel unlocked.
    Some automatic cars need to be started to idle for 5 mins to circulate trans fluid every 200 towing miles.
    Go to youtube and view, “ 4 down towing behind an rv. “. See how to install and use the system.
