- dons2346Explorer
Monty-Rob wrote:
Agree....SD wants UVW, but where can you find this number when looking at specs online...I have not seen this weight noted....guess you have to call manufacturer
There should be a data plate somewhere in the coach - Monty-RobExplorerAgree....SD wants UVW, but where can you find this number when looking at specs online...I have not seen this weight noted....guess you have to call manufacturer
- dons2346Explorer
Old-Biscuit wrote:
UVW (Unloaded Vehicle weight) Dry weight/Brochure Published Weight Etc
GVWR (Gross Vehicle Weight Rating) Maximum Weight Vehicle is Rated for
GAWR (Gross AXLE Weight Rating) Maximum Weight Axle is Rated for (by RV MFG.)
GCVWR (Gross Combined Vehicle weight Rating) Maximum Weight of Vehicle AND Towed Vehicle Weight
SD Registration.......License Plate
These fees are based on the weight and year of the vehicle.
(GVWR) plus AGE (split schedule 0-9 yrs and 10+ yrs)
Unless things have changed since I registered in SD back in '03, they wanted dry shipping weight.
I suggest the OP call the treasurer's office to verify. - Bill_SatelliteExplorer III could not get the unloaded weight but if you can find it you will save money. I had to go to a weigh station and weigh the coach so I paid a bit more than I would have needed to if I had the correct information.
- Old-BiscuitExplorer IIIUVW (Unloaded Vehicle weight) Dry weight/Brochure Published Weight Etc
(GVWR) plus AGE (split schedule 0-9 yrs and 10+ yrs) - dons2346ExplorerThey want dry shipping weight also known as UVW (unloaded vehicle weight)
- jpmihalkExplorerWhen we registered our Hurricane they wanted the weight from the manufacturer's certificate. This is typically the GVWR.
- sgip2000ExplorerMost likely GVWR.
38,707 PostsLatest Activity: Jan 05, 2014
