- old_guyExplorerwhere did you place the regulator? if at the TT then you have it in the wrong place. but once the hose bulges, it is time to replace. they have new hose out now, say it will be a better hose. it is not white it is a bluish green with very strong fittings
- BusskipperExplorerYes replace it.
- supercubExplorerYes, I use a regulator, and it's bulging with it attached.
- Dutch_12078Explorer IIIYes, it's time for replacement. Do you use a pressure regulator at the tap when you connect it?
- 2oldmanExplorer IIIt's a sing the pressure is high.
38,761 PostsLatest Activity: Mar 15, 2023
