OctaneforceExplorer IIJul 31, 2022Who has removed bell cranks?My coach (in sig) drives absolutely terrible. All p30’s drive bad but mine is becoming dangerous despite the thousands of dollars ive put into it. I was under it while a helper was turning the steerin...Show More
dodge_guyExplorer IIJul 31, 2022You will never be able to move it by hand. If it was moving with the steering wheel, then it’s bad. Replace it and drive it!
Related ContentStaple RemovalSuper Steer bell cranks for Freightliner XC chassisBell TvEasy way to remove slide topper?crank up antenna won't crank up
