TimfmCT
Dec 21, 2013Explorer
Scott, thanks for the info. I think having the bike on the back of our Ford Ranger would expose it to quite a bit of wind, buffeting etc.
Truth be told, if lucky, we'd have dry sailing form Ct to Fl.and no protection needed. But......
Now, I'm thinking about another approach. No cover, but apply something like S100 corrosion protector on exposed parts that I'm concerned about,especially the rear aluminum rim.
BTW when I googled Ultraguard motorcycle covers "Ultragard" came up.
I think your cover was more than $49.95.:S
Maybe, someone has actually used the S100 corrosion protector and may have some feedback.
Thanks again for your reply. BTW your set up sure looked good.
FIRE UP wrote:
Tim fm ct,
Well Sir, this is a bit of a tough one. You see, in an enclosed trailer, it's not problem because, when you tie it down, the tie downs do not get in the way of a cover because there's no need for a cover INSIDE the trailer.
But, when you tie a bike down, either on a lift, like what I and many had and presently have, and or, inside the back of a pickup, the tie downs get in the way of really cinching down a good cover. Ultraguard makes a travel cover that has multiple straps, buckles, gathering points etc. that really make it snug to the bike. It even has little "slits" in it for possible places to run "some" tie downs through it.
Well, that's perfectly fine if, IF, your tie downs just happen to be placed on the bike and, tie to whatever you're tying to, in just the right spot. But, as in our case, they (all 6 tie downs) were no where near the slits provided so, that makes for a very difficult time to really "seal" up a bike to keep it from the elements/dirt/debris/salt/rain/ etc.
That cover, is by far, the best travel cover made. It's about as thick as a real good sleeping bag. And, it conforms to multiple, normal protrusions like the windshield, handle bars etc. And because of the multiple buckles and cinch points, it really CAN snug up extra tight so there's no possibility "etching" of the paint. This is not a flimsy "throw over" cover just to keep the sun off. This cover means business.
But, if one gets one of these covers, then a good upholsterer is needed to "fit" that cover on your bike, with tie downs in place so that appropriate slits can be inserted and then "Button hole stitched" to keep them from running or un-raveling.
The other problem is, even if you were to get that Ultraguard cover and, have it modified to accept all your tie downs, the problem is, install it and working with it in the confined space(s) between the bike and the side beds, and front. I know because I tried it. Other than an enclosed trailer, it's pretty tough to really seal a bike, especially a large cruiser, i.e. Goldwing, Harley Street or Ultra Glide, Yamaha Venture full dresser and more to the point that there's no possible infiltration of the exterior elements and contaminates. Good luck.
Scott
