- racerguyExplorerLooks like we'll be in ours for Christmas, out of necessity. The addition we started on our house in August has run into a few snags and now it's so cold here most of the contractors can't get their work done.
It hasn't been above 20F at our place for 5 days. The forecast says we might see it above freezing by Wednesday so maybe they can get the drywall done before the weekend. Once that's done we might be able to use more than just the kitchen. - hipowerExplorerWe're settled in since Nov 26th for the duration here in LadyLake FL so we'll be in the coach for Thanksgiving and Christmas
- ctpresExplorerRV is overload guest house for us. Treating DD and SIL to exclusive use - for duration of holiday stay.
- SnomasExplorerWon't be in the RV for XMAS, but will be in it for New Years in Sedona. Leaving right after xmas and heading south. Should have left in November and would not be sitting here now in the coldest Artic blast thru Denver in a long time!
- mychrissyExplorerWe're leaving Tuesday for a few days in Dahlonega, Ga., Mama Gerties in Swannannoa, NC, Christmas in Charlotte, NC with family...
Getting excited. - HeisenbergExplorerAbilene ... prettiest town that I have ever seen!
- JTHarleyExplorerIf the temps get that low here are a few tips from someone who has been in sub zero beforeā¦.
Pull in the slides. (It will hold the heat better)
Disconnect from the water source and keep some in the fresh tank.
Have full propane tanks, the heaters will run a bunch.
Put 100 watt bulbs in the plumbing bays.
Fire up a space or cube heater in the bedroom and living room.
Pour a tall scotch on the rocks, put on your snuggie and watch Michigan State beat OSU!! - kjburnsExplorerWe'll be in Tucson, at LazyDays, to visit my family.
- GoldencrazyExplorerInsulation on the hose may not be enough. Heat tape would be better. I would put some water in tank or use bottled until it warms up and turn off water at source, unhook hose and drain. Put light bulbs in your bays to add heat where any water or pipes are exposed. Amazing what a light bulb will do in a closed in small space. Plenty of propane to run the furnace and settle in. If you have enough snow shovel it around the motorhome so it is up to the bottom of the coach. it will be a great insulator for underside area. Assuming you didn't cut plywood to enclose the underside area.
ncrowley wrote:
We are living in our RV in Hurricane, Utah waiting for our house to be built. It will not be done until the middle of January so we will be here on Christmas.
I am sitting here watching the snow fall hard outside the coach. I am not sure what part of "We hardly ever see snow here" I misunderstood, but this is the second snow fall in a week here. The worst part will be the night temperatures. The forecast is for 1 degree on Sunday night. We have insulation on the hoses and we will drip the water but I am not sure that will be enough. Has anyone gone through these types of temps? - bobkatmsuExplorer IIHaving dinner with my Dad on his 90th Christmas. The motorhome will be packed and in the drive. As soon as dishes are done we are heading for Blue Water Key RV Resort, in Key West. Think it's 5th year in a row. Our 32nd anniversary is NYE. Always a good party in Key West.
38,776 PostsLatest Activity: May 14, 2026
