bar_20
Nov 14, 2013Explorer
Class C motorhomes are made from the inside out. The frame is built, the cabinets are installed before the siding is put on. The class B is built from the outside in. Much more labor involved in building a Class B. If you compare an inexpensive Class C that sells new for about the same price as a new class B there is no comparison in the quality. Class B's are not for everyone. You can usually get about 25% off MSRP on a class C while class B's are usually around 15% off MSRP. You don't need to haul a toad around with a class B because you use it as your go for vehicle. Some people use them as a second car.
38,777 PostsLatest Activity: Jun 28, 2025
