rgatijnet1
Aug 26, 2016Explorer III
If you have a radio, as well as the CO detectors, you will always have SOME draw from your batteries. This is to keep the channel memory intact and the CO detector functioning. There are other things that may also be causing a power draw such as leaving the Inverter/charger/converter on full time, lights in the basement compartments, mirror heat, etc. Check to make sure that all 12 volt items are turned off and you will probably find something that you left in the on position.
38,782 PostsLatest Activity: Aug 31, 2026
